I think the one I have is older. It includes the train and track. It's orange, brown, and beige colors. Thanks tho
SOURCE: I need instructions for assembling the 101 Piece Deluxe train set
Here is the URL for Kidkraft's site. You should be able to find what you need there.
http://www.kidkraft.com/assemblyinstructions.asp
SOURCE: trying to identify older tasco telescope and put it together
There are only two types of telescopes --- REFRACTORS, and REFLECTORS-
The refractor has a lens on the front of the tube and you insert different eyepieces in the back-- the larger the number written on the eyepiece the LOWER the magnification-- (DO NOT USE THE 2x or 3x barlow which you may have!-- this creates too much power for this small telescope!-- put it away and never use it!)
A reflector has a main mirror on the bottom of the tube, and a small secondary mirror under the eyepiece hole (focuser end) - front end-- put the lowest power eyepiece into the focuser.
Now with either type telescope go out side during the day and practice focusing on a distant object-- turn the knob SLOWLY. At night the moon should be the first target you try.
If you received what appears to be a smaller telescope -- that is the finder scope-- attach it to the top of the tube on the main telescope. Again during the day line up the small finder scope with the main scope-- look at a distant telephone pole (the very top-- and center this in the main telescope. Without moving the main scope use the finder scopes "screws" to adjust the cross hairs so they are pointing exactly where the main scope is pointed. Now you can use the small finder scope to point the telescope in the exact direction--
The moon should be your first night time target.
Good luck--
SOURCE: instructions
I am assuming that the rails are not locking for you. The problem is the safety feature which prevents the sides from locking (and unlocking) if the bottom is flattened. The bottom needs to be raised about half way for the locking mechanism to operate. Hope that helps. [email protected]
SOURCE: I need the instructions for the Thomas the Train Set
http://www.tomy.co.uk / webcare / product-instructions / track-master-tmrr-instructions /
Testimonial: "Thank you so much -- I am forever grateful!!! "
SOURCE: music will play but train will not move or do any other function
I'm not spending money for asking if there is a button to push to make the train go around the track! That is a simple "yes" or "no" answer! I can promise you that I will not buy another product from your company and will tell all my friends about my experience with your product!
Spaldingsr
