SOURCE: Frigidair Gallery self cleaning stove
Hey charles
This often happens after you have gone through a cleaning cycle. In most cases the relay contacts has been welded shut to one side or burnt off. The relay can be replaced or the contact freed. Otherwise the controller (clock) has to be replaced (easier).
Regards
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
SOURCE: CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
