A
Anonymous Posted on Nov 17, 2017
Is there a loud speaker setting on the panasonic KXTGA131EX
Bill Willard
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Nov 17, 2017
Bill Willard
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
16225
Points
138
Look on the button that allows you to back up or go forward in your voice mail messages. My Panasonic machine has < > for messages (left push/right push) but also + - for volume (down push/up push)
2answers
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
I have a panasonic kx-tga271 handset. The speaker phone, the ringer and keypad noise do not work. Is it fixanle?
It could be the speaker. I have a handset with the same issue. The internal speaker which produces these sounds broke. If you can find a small speaker that fits inside, its an easy fix - - just take out the screw inside the battery compartment and carefully undo the plastic assembly. The speaker is held in place with a plastic anchor that twists off. There are two dots of solder which attach the wires that will have to be melted and resoldered on the replacement. Anyone thats handy can fix this. Look for a used handset for parts. You might also consider breaking apart a cheap set of headphones for the speaker. It won't be as loud, but at least the sound will be restored to some degree.
2helpful
SOUND KEEP COMING IN AND OUT,LOUD HISS FROM SPEAKERS
theres a short in the wires either inside the box where the speakers are or the channels are blown.
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
My Panasonic TH42PZ80 makes a slight buzzing noise when switched on - is this usual or is there a problem?
If the buzzing is coming from the set itself rather than the speakers, then this is normal. The bussing should only be loud enough to hear when you are close to the set. If it is loud enough to hear from across the room, it is not normal and could be a sign that the power supply is starting to fail. Which case best describes your situation?
Dan
1helpful
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Buzz in the speakers of a system with a Panasonic CQ-VA70EU
check your speaker polarity and recheck all pos and neg grounds
Sound and speakers
Check the speakers connections. The speaker cables may be shorted. Turn the unit off, check and correct the connections and turn the unit on. good luck :-)
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
