Baking soda, Epsom salts, sea salt, vinegar for helping to remove hard skin, lavender and/or sage and other herbs, oils and whatever your imagination or research can discover.
Caffeine is reckoned good for feet and legs so I guess feet could benefit and menthol shampoo makes the scalp tingle and might put a spring in the step of anyone who adds a few crystals to the footbath...
Yes you can add those chemicals. But keep in mind any salt is corrosive.
SOURCE: Vinegar
Do not add anything to the tank.... Vinegar is corrosive and that would potentially be very bad.
SOURCE: A white residue is on dishes. It must be washed
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
SOURCE: code 93 saltwater system
i set my saltwater pump to run for five hours and after 1 hour it goes to sleep. my water stays cloudy looking. what can i do?
SOURCE: I have a homedics foot
According to the manufacturer it is not recommended you use Epsom salt in this product as long term use can cause corrosion to the water jets. I hope this helps.
