this is a common windows error. if a certain application stops working like your google chrome. try to edit start up items, click on start, click run, on the run box type : msconfig. click ok. on the start up tab, click on disable all on the bottom right, hit apply or ok. it will give you a prompt to exit with restart. this is for xp, if its vista more likely the same but after restarting the computer, no prompt for system configuration utility will pop up. to unisntall the google chrom, if its xp go to add remove programs and click remvoe, if you have vista, go to program and features and uninstall it from there, if no go. use the microsoft installer clean up utility. http://support.microsoft.com/kb/290301 just download and install it then look for it under programs and it will gie you all the programs installed on your computer, you can look for google chrome and uninstall it. that should work.
Let me know if the problem remains , note that if the chromes own uninstaller fails, the revo uninstaller can do things on its own, so you can manually remove it in any case with the tool.
Seems like you sent the qestions two times, well try revouninstaller - http://www.revouninstaller.com/ try the moderate options first, or advanced if you wish.
Option #1
1) Back up the registry on an affected system. 2) Open the registry on the Agent system by entering regedit from a run prompt. 3) Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SysPlant. 4) Open the Start DWORD. 5) Change the value to 4 to disable the drivers. 6) Reboot the system to commit the changes.
Option #2
1) Navigate to Control Panel and Add/Remove Programs for XP or Programs and Features for Vista. 2) Scroll down to Symantec Endpoint Protection and hit Change or Modify. 3) Choose Modify from the Symantec menu. 4) Uninstall Application and Device Control from the menu. 5) Restart your computer. 6) Attempt to reinstall Google Chrome.
1) right click on the google chrome icon on your desktop
2) click on properties
3) click on shortcut
4) where it says target and the end put a space and then --no-sandbox 5) press apply and then ok and it should work if this does not work i am sorry but this is what worked for me
