SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
SOURCE: HOW TO UNPAUSE MY PRINTER
In Windows XP, click the start button, then click Printers and Faxes
Double click the printer in question, then in the window that opened, click the Printer menu, then click Pause Printing.
SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
SOURCE: Hi I have an hp
Look for your printer on the bottom right hand of the screen (where all the little icons are). and find the printer, double click it, and this should open up your printer options. From there you should be able to find the jobs and modify them.
Hope this helps.
Tv is working, check all input connections.
