Motor Control Board Upper Board Console Replacement Change HOW TO
Blessing
[email protected]
cell+whatsAPP:+50588611441
SOURCE: nordictrack audiorider r400 checksum fail
Remove
the bolts or screws securing the console to the upright assembly. Lift the
console and confirm that the cable connections are secure. Remove the cover
from the console's battery bay and install a fresh set of batteries. Replace
the battery cover. Detach
the ends of the pedals from the crank axles. Remove the left and right disc
shields and side shields. Inspect the interior of the base unit and locate the
flywheel. Inspect
the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the
flywheel until the magnet passes in front of the nearby reed switch. Loosen the
screw securing the switch in place. Rotate the switch to reduce the gap between
it and the magnet. Tighten the screw. Replace
the left and right disc shields and side shields. Reattach the ends of the
pedals to the crank axles.
Finally tight the flexible cord form keypanel vs display board and then tight the display board vs lower board.
See if you can meassure +5VDC from lower board to display board.
see the block diagram for your final diagnostic.
Sincerely. Merry Christmas.
Ernesto cuadra
managua,nicaragua. c.a.
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
