Any idea what may have changed? No one has touched any programming on this system in years.
Have you paid your bill? maybe your telecom company restricting outgoing calls. do you have lines 4,5,6 that work?
Sorry, forgot to mention this is only happening on 1 extension. We tried swapping another phone and we get the same results. All other phones (extensions) work fine.
bad wiring on the port. Take off faceplate and check all wires are secure - compare the wiring to another port known to be working
I found the manual and was able to use remote station unlock to fix it. Somehow the user locked the station. In case anyone else wants to know, go to programming extension, enter progamming code (default is **1234), then PROGRAM, 99, 01, ENTER EXTENSION # TO UNLOCK, 1 TO UNLOCK, AUTO DIAL/STORE THEN PROGRAM TO EXIT. Thanks for your help though!
Also, our system was the Panasonic KX-TD816
SOURCE: programing
Try the instructions on the Panasonic Website. http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Super-Hybrid-Phones/model.KX-T7453.H
SOURCE: panasonic kx-t7453, night mode message programming
Do you mean have calls transferred to voice mail? Go into system programming and change 408 (DIL 1:1 Nite) to point to the ext of the voice mail port, which depends on your system. That number is found in 118
SOURCE: Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
SOURCE: How do you change the main display name on a Panasonic KX-T7453?
hello,
enter the menu of your phone, go to profile choose the profile you want and personalize it.
when personalizing change the name of the profile to the you want and activate the profile.
i am sure it will display your name.
thanks for using our website.
