I have a pair of Logitech S-100 speakers but cannot get them to play on my Dell Windows 7 professional 64-bit machine?
First make sure you did not accidently set them to mute.
It is a regular audio output plug so it should work fine with the Microsoft drivers, without special drivers. Do they work plugged into something else? Do other speakers work on the Dell? Do they work when you wiggle the plug? Those 1/8" headphone jacks are notorious for poor connections.
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
SOURCE: I need a driver for my Sony Handycam DCR-HC20,
You can find it on the Sony support website. This link takes you there.
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
SOURCE: Needs USB-MIDI Driver For WK 110 Piano for Windows 7(64 Bit)
Here is tie official site for the driver ... http://driverwhiz.com/drivers-en?brand=Casio&logo=Casio&subid=1001-us-en-10000000394&gclid=COT9m4uGhKACFdx05QodUT3Zkw
Evidently Casio has not written drivers for Windows 7/64 if I understand your comment. I am not that familiar with 7 but I do know in past versions, Windows has offered "compatability mode" so older devices might work with newer operating systems. Have you explored this possibility?
Here are the options I see:
Look for compatability mode on your new computer.
Ask Casio for a driver.
(I'm not a big fan of third party drivers - maybe you are - you can look for a third party driver)
Continue to operate your WK 110 using a 32 bit computer.
Thanks for your interest in FixYa.com
SOURCE: Windows 7 64-bit driver for Canon LBP-2410
hi..try this link ( http://support-au.canon.com.au/EN/search?v%3aproject=ABS-EN&binning-state=model%3d%3dLASER%20SHOT%20LBP2410%0Amenu%3d%3dDownload%0Aos%3d%3dWindows%207& )
SOURCE: Windows 7 64 bit, cant
Download driver files:
Click the link below:
http://www.logitech.com/en-roeu/434/6007?section=downloads&osid=14
* select windows 7
*select file --- SetPoint 64-bit
* click download software.
* install the software.
