SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
SOURCE: error messsage cal for service E1-88 from sharp AR-5127
Unplug the Machine, remove the board you installed, re-seat the board,
make sure everything is connected, turn machine back on..
This is what the Manual says:
IMC PWB communication trouble (Timeout)
Check the connectors of the IMC PWB
and MCU PWB.
Check the grounding of the copier.
If you need further help let me know..
SOURCE: Sharp AR-M350/M450 scan to desktop
Network scanner tool (or NST) comes bundled with the Sharpdesk application. It can be loaded as a standalone but it is bundled software. If you have dealer access to Sharp's website you could download the software from there.
If this is a client of yours you should be selling them another copy of the software as it is no fault of your own that they misplaced the CD plus its extra revenue.
I would love to help you otherwise, but this is copyrighted software.
SOURCE: It display
Check the white area of document glass and clean it or the copy lamp is not lighting.
