Dishwashers Logo
P
Peter Loth Posted on Nov 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Nov 14, 2017
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
870015
Points
8043
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
  • 1 more comment
  • Peter Loth
    Peter Loth Nov 15, 2017
    Very good suggestion but still having problems so will need a repair man. Thanks
  • Scott Hytch
    Scott Hytch Dec 06, 2018
    Hi Peter I have the same problem with our dishwasher what was the out come
  • Scott Hytch
5 Related Answers
Anonymous
  • Posted on May 06, 2007
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. [email protected] - replace "_dot_" with "." to email me.
douglas smith
  • 1462 Answers
  • Posted on Jun 22, 2007
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Anonymous
  • Posted on Apr 06, 2009
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Anonymous
  • 218 Answers
  • Posted on Jul 03, 2009
SOURCE: Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Anonymous
  • 725 Answers
  • Posted on Sep 27, 2009
SOURCE: ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
I have an lg dishwasher that showed an ie error so I fitted a new inlet valve It now shows an FE code?
The drain pump automatically runs when the FE code is displayed. A leaking water inlet valve or a stuck relay on the electronic control board can allow water to fill the dishwasher constantly. To check for a leaky water inlet valve, unplug the dishwasher and see if the tub continues to fill with water. If it does, shut off the water supply and replace the water inlet valve because the valve is letting water to flow into the dishwasher constantly. If water stops filling when you unplug the dishwasher, then you'll likely need to replace the electronic control board because the control board is constantly sending current to the water inlet valve
3answers
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Dishwasher is not error ie and not enough water in tub. I put in water manually and runs fine.
here are couple of thing to look for,always remember a dishwasher is not ground in certain parts,,,
you get error code ie if the dishwasher has not filled to normal fill in 10 min,s make sure water supply its on and open all the way,,,make sure inlet hose is not kinked,,check water pressure has
to be over 12 psi ..weak water at sink hot weak water at dishwasher,,you may have a clogged in let vavle or inlet hose screen..reminder the water is not going in dishwasher in the alotted time start there..good luck for mor help repost...
Displaying code IE
Hi jakkirker,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
1helpful
My lg ld 1403w1 dishwasher fills with water and then error code I.E appears have bailed out water and tried it three times same result
Hi june1245,
I.E means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame (varies on model) - Make sure of the following first:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Un-kink it.
Kind Regards :-)
Jedemeyer1
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
2helpful
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
My LG LDS5811ST has error code of IE Where do I
1-Check if the water Inlet Hose is kinked.
2-The Water Pressure is very low.
(below 10 psi)?
3-Inlet Valve is OK?
by water filter?.
The panel has a LE ERROR.
LE is an ie .. water inlet problem. ... manual says to check for clogged, kinked, or frozen water inlet hose. check water supply.
OE. Drainage problem
FE excessive water supplied
E1 water leakage problem
HE heater circuit failure
TE thermistor failure, or very high inlet water temp
PF. power failure.
Lg LDS 5811st IE code
With an LG 5811 diswasher, when the IE error code is not caused by kinked hot water hose or blocked screen, the next step is to measure the electric resistance of the Inlet Valve. (950-1300 ohms)
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
