SOURCE: Panasonic microwave Genius Sensor 1250 W
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: panasonic inverter dimension 4 microwave
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter or a bad magnetron.
SOURCE: panasonic microwave oven error code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
You can find an authorized Panasonic servicer here.
SOURCE: Panasonic Microwave NN-A770S getting hot on right side externally
Is it normal for a Panasonic nn-c994s to cycle the fan/inverter
when using combination cook?
16 sec off 6 sec on.
Everything else seems to be working
light, timer counting down, heating food, turntable turning
SOURCE: need a manual for a panasonic inverter combi
my microwave is saying h98 what does that mean. it's a panasonic inverter.
