SOURCE: how to bypass lid lock control on kenmore elite oasis type 581 washer model 110.28032701
there isn't any way to bypass this type of lid switch as in the old 2 wire type lid switches,as the 5 wire type lid switch you have has to be connected to the control board located behind the control panel,it has to see the lid is closed and sends a magnetic signal to the control board to start the wash cycle
SOURCE: kenmore top loading washer locking lid switch bypass
Yes. Snip the wires at both sides of the switch. Then fuse the wires together with electrical tape. But before you do that...you state it's a 2011 model? It should still be under warranty.
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
SOURCE: Whirlpool washer lsq9010pw -Timer not advancing
you can also check to see if the timer motor is good. not a good idea to bypass. if the presure switch was bad it would not stop filling up.
