SOURCE: i have an evinrude etec 115 , water is leaking
check the seal at the pick up tube. If you have a strong water pressure at the tell tail, no need to worry it is normal.
SOURCE: overheating and overcooling on a 150 etec evinrude outboard
Get a outboard sea foam from walmart or local parts store. Mix with gas and oil should help it if it doesn't I would recommend take the whole thing apart and clean it. Check lines to see if clogged etc.
SOURCE: my evinrude 150 etec seems to have a miss through all rev ranges
Hi Terry..When were the spark plugs replaced in it last?.it could be a nice easy fix if it has a dodgy spark plug in it..Other option is to check plug leads for cracks & coil casings for cracks as well..
SOURCE: Why is it hard to steer a 2009 25 HP evinrude etec?
Hi Pablo:
I'd be looking for corrosion at the rotating bushing. There should be grease nipples to get lube into it. Grease, and lots of moving it should loosen it up.
