SOURCE: Innovage jumbo universal remote code
try this website, you have to scroll down and find "Innovage" on the list and then it will download the pdf of the manual.
http://www.xdiv.com/remotes/
SOURCE: Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
SOURCE: Dish Network universal remote
Here are the codes for Orion tv's for Dish Network remotes.
Orion: 694, 720, 729, 220, 221, 623, 695, 227, 754, 721.
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
SOURCE: I need a dish network remote control code for an ESA television.
try some of the akai tv codes in dish network directory, firstone worked for me, hope it works for you
chris
