The RC2011V remote came with several different Viore TV models, including the LCD22VH56. Manuals Lib has the manual for this TV here: https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html . The remote is described on page 10; the link to that page is https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html?page=11#manual . Additional information on using the remote with the built-in DVD player on this TV is in the DVD section. This starts on page 15, https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html?page=16#manual .
I hope this helps.
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
SOURCE: Viore 52' TV randomly shuts off. front lights blink then stop.
I purchased the TV two years ago and called about the warranty because the TV was shutting off with no warning. Called the Company out and they said that it was the bulb. It was the worst TV in the world. WalMart sold me a warranty on this thing that was no good. It didn't help me at all....was a waste of money.
SOURCE: Viore tv won't see dish network
I will assume this is a direct connect from the wall plate to the TV. With that said you need to run a scan on the set to lock in the channel the second TV is modulated to either 60 air or 73 cable usually. Go into the menu on the tv and select the auto channel search. Some sets scan both sides at once others require you to choose cable or off air. Once this is done you should find the signal.
Let me know if you need further assistance.
Thanks for using Fix Ya.
SOURCE: code for viore tv through directv remote
buy a vcr and antena in,antena out toTV you can change channels all day long.but volume has to be worked by hand.
SOURCE: Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
