Question about Kitchen Selectives CM-202 Coffee Maker
Kitchen Selectives three pack- coffee maker,can opener,toaster
Bought 3 months ago and have had nothing but problems with the toaster not always shutting down when bread pops up, the can opener is for the birds also only works when it wants to. As for the coffee maker what a joke not for the hard coffee drinkers clogs to fast and doesn't do what the papers say it will. However it was only 19.99@ walmart. Get what you pay for I guess.
SOURCE:
SOURCE: Need Replacement pot for black Kit. Select. Dual Pot Coffee Maker CM-202
Select Brands
Kitchen Selectives
Select Brands
Customer Service Or Call 913-663-4500
To order replacement carafes for the CM-202 Dual Coffee Maker you have to call Customer Service at 913-663-4500 - This item cannot be ordered on line.
Posted on Jan 01, 2009
  • 3 Answers
I also have a broken pot for the CM 202 dual pot coffee maker and today I called 913-63-4500 and ordered 2 new pots at a cots of $7.00 each. 2 pots plus shipping was $26.00.
Good Luck
Posted on Jan 28, 2009
SOURCE: Need replacement lid for coffee pot
I called Select Brands at 913-663-4500 to order the replacement caraffe for this coffee maker. Their email is orders@selectbrands.com The website is under construction so orders cannot be placed online. I broke my coffee maker yesterday and still have my lid - guess I'd better keep the lid....
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
I guess you would have tried using just water by now. I would think that would be the right thing to do but to which it and if the water freezes you will a anti-freeze solution or it willl cause massive damage.
Posted on Aug 03, 2009
cr_100808
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps!
Posted on May 29, 2014
Kitchen selectives double coffee maker parts
Fixya is unable to suggest sources for Kitchen Selectives parts.
Aug 30, 2018 | Kitchen Selectives Coffee Makers &...
Tip
How to Clean Your Toaster
Most Toasters Old and New have a trap door. Some have trays to catch the bread crumbs which can burn and even catch fire if not removed on a regular basis. Just open the trap door over a trash can and brush the crumbs away. Never put oils on the bread before toasting. This could cause a fire. Always unplug the toaster when finished.Not only will this help keep bills down but it can also make sure your toaster is not the cause of an electrical fire while unattended.
on Mar 10, 2010 | Kitchen Appliances - Others
My breville toaster model BTA840XL won't drop the bread in for toasting
If your power-socket is off, it won't. (I've done it several times, foolishly cursing the toaster). :rolleyes:
Otherwise unplug from wall, remove covers, check by pressing base down with a pen etc. On most auto-eject toasters, a powerful electromagnetic solenoid (electric magnet) holds the base (slice carriage) down while cool and warming up. When preset temperature is reached, solenoid is de-energized, releasing its magnetic hold on the base, allowing springs to pop bread up.
If you (or friend) has a tester and expertise, check solenoid (small coil) for resistance. If OK, (not open circuit), problem is in control circuitry.
Dec 18, 2016 | Breville Kitchen Appliances - Others
Looking for paper filters for kitchen selective one cup brewer
You don't need paper filters it has a 'permanent filter'. That means it has a fine mesh nylon filter that you rinse and re-use.
Kitchen Selectives Single Serve Coffee Maker Permanent Filter Mug Included
Nov 28, 2015 | Kitchen Selectives Coffee Makers &...
I have the 1193 bread maker and I have loved and used it for years. Last winter, we built a new wall cabinet and made an enclosed shelf for the bread machine above a new wall oven. The shelf is open in...
Hi, I recommend that you move your bread machine from its exalted place of honor, just to test it and see if it is getting too hot to function. Move it to the countertop and try making a loaf of bread in it. If it stops again in the mixing cycle then its time to get a new machine. If it doesn't shut down and keeps going then you know that the enclosed space you created for it is causing the problem. I don't have a 1193 in stock but I have a variety of other machines in stock including a Toastmaster (different model #)! Hopefully you won't need to replace. Please share with me what happens when you do your test.... good luck!
Jan 03, 2011 | Toastmaster Breadmaker's Hearth 1193 Bread...
I'm looking for the coffee pot only for kitchen selectives cm-312-p, where could I buy one?
Select Brands, the maker of Kitchen Selectives, doesn't list your model. This might mean it's no longer in production or was a custom model for a retail outlet. This page at their site gives contact information. All I can suggest is that you contact them and see if they can tell you where you can find an original replacement, or see if one of the universal replacement carafes at retail stores might be a close enough. Good luck, and thanks for using Fixya!
Dec 15, 2010 | Kitchen Selectives CM-202 Coffee Maker
Lever on toaster will not stay down
For what it might cost to fix it buy a better brand of toaster for about 10% of the cost of this horrible brand.
You'll notice their new ones are "smart" toasters with NO LEVER. You push a button and the electronics takes care of the rest (and blow up quickly.)
$15 to $25 at Walmart.. instead of $100 to $200.
Dec 13, 2017 | Breville Kitchen Appliances - Others
Coffee Makers & Espresso Machines Logo
81 people viewed this question
Top Kitchen Selectives Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Terry
Terry
Are you a Kitchen Selectives Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
