Question about Tablets & eReaders
How to unlock an ipad - Tablets & eReaders
  • Roger Garcia
    Roger Garcia Aug 22, 2019
    You can use ApowerUnlock to unlock your iPad whether you forgot your Passcode or Apple ID.
    Master:
  • 498 Answers
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
how to unlock an ipad - restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
Posted on May 06, 2019
    Top Expert:
  • Tablets & eR... Master
  • 29,343 Answers
You can't, you have to Factory Reset it also known as a Hard Reset.
Connect it to a computer with iTunes on it, connect the iPad, sign in and then choose Hard Reset. You will get the option to store what you have on iCloud as long as you opted to back up there.
If it is an iPad that has phone connectivity and mentions needing a PUK Code, this can only come from the Cellular Provider that owns the iPad. You have to phone them.
Posted on Nov 12, 2017
6ya staff
SOURCE:
Ave a lock screen on my Ipad and cant remeber my apple ID
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPad with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPad". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Dec 04, 2016 | Apple iPad Tablets & eReaders
How can i transter pictures from my disabled ipad to the laptop?
If the pad doesn't work then there is no way to transfer the pictures that I know of.
Sep 21, 2016 | Apple iPad (16 GB) WiFi Tablet PC
I have a iPad mini that says activation lock. I bought from someone. How do I unlock it?
This means the ipad is reported stolen by the owner and is being tracked.......the owner is the only person who can unlock it!
it is a security app, 'find my ipad' and cannot be unlocked without the apple id!
Sep 07, 2016 | Apple iPad Mini
How to unlock ipad2 puk code
Your iPad 2 must have 3G, with a sim card. For the sim you need the pin and after 3 misses you need the puk. The puk is on the letter or card that came with the original sim card. On that letter is the pin and puk. sometimes you have to scratch away the metal layer.
If you want to unlock an iPad, with the lock code on, and forgot your pass code you have to enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Jul 09, 2014 | Tablets & eReaders
You need to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do a restore:
unlock-ipad-of1o0fkyrymqaiqlgkygvvrr-3-0.jpg unlock-ipad-of1o0fkyrymqaiqlgkygvvrr-3-2.jpg Restore iPad to new factory condition Restore iPad to new factory condition
May 13, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How can I unlock my iPad?
Hold the power and home buttons at the same time until you see the Apple logo, then release.
Dec 29, 2012 | Apple iPad 2 Wifi 16GB
How to unlock jailbreak on iPad?
If you prefer a simple yet fast solution to jailbreak your iOS device. You can take a try of AutomaticiPhoneUnlockers.com, it can help jailbreak or unlock as many iPad, iPhones, iPod Touches as you like. Both Windows & Mac OS X are compatible.
May 31, 2012 | Apple iPad 64 GB 3G Tablet PC
Haven't used my ipad in a while, and forgot my password to unlock. help
click on Safari, click on open book icon, top of page, find iPad help on drop down menu...(last one)
May 05, 2012 | Apple iPad 2 Wifi 16GB
How to unlock ipad for free
It is possible to unlock your iPad (or other iOS devices) now. And if you prefer an easier way to do the job, see how you can achieve it on your PC or Mac on your own from this website: www.automaticiphoneunlocker.com
Mar 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
Tablets & eReaders Logo
340 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
