Looking for a manual for a Haier Super Capacity washing machine.
SOURCE: Maytag (Super Capacity) Front Load Washer Manual needed
Click on 'washing machines' (below FIXYA) on this page, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is.........& rate me pl.
SOURCE: my washing machine is taking a long time to fill.
Have you checked the inlet filters on the water hoses ?
If you unscrew the water hoses from the machine, and look inside the connections on the machine, you should see the filters - they are usually a plastic "cage" supporting a gauze or fine mesh. These can be pulled out (you may need tweezers or fine nosed pliers) and washed under a running tap.
If this doesnt cure it, check that the water supplies where the hoses connect to your house plumbing are actually fully on and flowing properly.
Otherwise, there is probably a fault with the solenoid valve(s) on the machine that controls the flow of hot water in to your machine.
Testimonial: "great suggestion! my life is so busy being a stay at home mom that i dont have time to wait forever for my washer. fixed it up great!"
SOURCE: MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
SOURCE: Where can I get the manual for the kenmore 3.5
See the following site:
http://www.managemyhome.com/
Click on the Manuals tab, enter your model number and you should be able to get PDF files of your manuals.
SOURCE: Looking for instruction manual for
just get your manual here :
http://www.google.co.id/search?rlz=1C1MOWC_enID396ID396&sourceid=chrome&ie=UTF-8&q=download+manual+of+Maytag+Super+Capacity+Plus+Stove
Regards
