After resetting the time, the stem of the watch can't be pushed back in so it is flush with the case, with no gaps.
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Identify the push button that controls the second hand. With the watch face positioned so that 12 is at the top, locate the button on the right of the watch's rim and above the watch stem.
Grasp the watch stem tightly and tug it out, away from the watch rim. Pull it past the first area of resistance, a position used for other settings, to the second stage of resistance where it will not pull out any further.
Press the second hand push button, identified earlier, until it is firmly depressed into the watch rim. Release the button, allowing it to return to its normal position.
Push the watch stem back to its original position tight to the rim.
