SOURCE: My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Thank you for your post, Cathie Sanchez!
I understand that your Frigidaire dishwasher is displaying error code "S" and will not restart. The error code "S" usually stands for sanitize, this could also be a miscommunication within the control panel. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for roughly ten minutes. If you continue to experience issues with the error code I would suggest having a professional technician out for proper diagnosis and repair. Hope this is helpful. -Matt
Hi
"Er Clean S" is a common error with Frigidaire which means
shorted keypad. The issue is with the touchpad/keypad that should be replaced.
However, before replacing the keypad you can unplug it and take it apart
completely and use a hair dryer to blow some warm air on the keypad assembly to
blow the moisture off. Hope this helps...please post back for further
assistance.
Daniel
Hi
shorted keypad. The issue is with the touchpad/keypad that should be replaced, under warranty.
blow the moisture off but again doing this will void warranty so decide if you want to get this done under warranty or you want to do it yourself. Hope this helps...please post back for further
assistance.
Daniel
