Date wrong too. is this just a battery issue ?
SOURCE: change date on my invicta 6676
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals.Rate me, please.
SOURCE: Invicta model 4562 7750 valjoux
Hi Friend,
Please check with the below link,which gives the detailed information about the Invicta Watches.How to set the Date and time in your watch.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
If you have any Clarification please write back to us
Regards,
Aysaam
SOURCE: How do I replace the "back" of my Invicta Angel
The back should be placed back, but you must know, in the raised edge is a little notch. that should point to the crown. then make sure it slides in the back and press with both tubs and fingers on two sides, till it clicks. You should have strong fingers and not bend the razed edge.
If tour fingers are not strong enough, you could try to put the watch on a table, back down and then press on the front. NOT on the glass, but on the edge. It takes some practice and be aware you could damage the watch beond repair, if you don't do it right. next time just go back to the store. It could cost a few box extra, but your watch will live longer.
SOURCE: I have a invicta bolt zeus and it stopped working.
If you suspect the battery try some spare batteries double checking with several known good to brand new one tests to cover your bases for consistency. It is a method of trial and error eliminating any possibility of a battery problem.
Sometimes there are power drain issues where cheep batteries even new can't handle. Trial and error illumination of a power drain issue checking with high power drain capable batteries. Information can sometimes be found in the manual in the specification.
From there you have the insight information it is not the battery in your further investigations describing the problem to a dealer or manufacture.
Other options of investigation include if you have the owners manual to check if there is any special settings to instigate you may need to know about dealers and the manufacture should know as well.
