Got error code E5 F3 when I got it into diagnostic mode. That code doesn't seem to exist for device. Model number is 110.2600.2011
Maybe it is F8 E5 which would be hot and cold water reversed.
Here is a complete list of codes, maybe take a picture and post
https://www.searspartsdirect.com/washer-repair/error-codes/kenmore-110-model-vmw-top-load-washer-error-codes.html
SOURCE: F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
SOURCE: F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
SOURCE: Kenmore Elite He5t Washer Error F24
If it is not the plug at the bottom is ok and the temp. sensor is ok.Check the plug on the CCU on top mine was not even plugged in. When I plugged it in the washer started working. You have to take the top off to get to it,but it is easy. Three screws on the back top and the top will slide off easily. There is a troubleshooting manual in the front bottom panel on right side of panel. Page 10 troubleshoots the temp. sensor. The book gives you all the troubleshooting codes. The front panel comes off easily by unscrewing three screws on the very bottom of the panel.
