In order to resolve the matter at first, you have to know more about the error code in depth. Basically Windows Update Error 80244022 arises when you run Windows Updates in yours Windows 10 PC/ Laptop as this error code indicates that it's a software update issue, hence it has numerous reasons for occurrence of this error, might be virus arise while connecting to the Microsoft Update website downloading, and installing the updates. But don't worry you can easily resolve this issue by following some steps.
Steps to Fix Windows Update Error 80244022 :-
Step 1:- Run DISM Tool
Step 2:- Troubleshooting the Computer
Step 3:- Manually Download Window Updater
Step 4:- Check Proxy Settings
I hope all the above techniques or steps will help to troubleshoot Error Code 0x80244022.
Hello; OP ANON:
no PC stated, maker of PC , who is the maker
then what model PC,
who installed W10, you>? or did you force update the OS from
other OS. fresh installed or updated from w7 or 8.?
all this matters, every word.
just windows 10 and not if it is 32bit or 64bit
click control panel click system see there is your TRUE OS.
ok>
then tell what PC you have, windows 10 doe not RUN on vast PC made, mostly do 2008 to now. ''
learn that W10 does not run on all PCs, for sure 64bit is very strict.
also tell , this,
run box, type system information.
see what processor you have, it has a number there.
Anything earlier than win will not update anymore as there is no microsoft support fro win 7 and win xp
updates are not dead in w7 , not yet.
SOURCE: HPDESKJET 3600 DOESNT HAVE A DRIVER
Check this: http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=304535
or purchase a driverutlity, which could help you install one and find the drivers for you.Check this: http://driverfinderpro.com/register/
