SOURCE: I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
SOURCE: Need to find Tanaka tbc Grass Trimmer,carburettor service manual
Hello
If the Carburetor OEM is a Zama, then
>>You can View a Breakdown/IPL of the Carburetor and Get Technical Information on Zama Carburetors at this Site Addy; http://www.zamacarb.com/tips.html and Select the Technical Guide.
If the Carburetor OEM is Walbro, then
>>You can View a Breakdown/IPL of the Carburetor at this Site Addy, http://69.16.165.8/ and Select Service & Aftermarket. Now Select Aftermarket Parts and Service. Now Select the OEM (Tanaka). Now Select Trimmer. Now Select your Carburetor (?) from the List Provided.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: THE GLOBE HAS STOPPED. WHAT SORT OF GLOBE TO BUY
contacted westinghouse distributor australia.thank you for your assistance
SOURCE: parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
SOURCE: where in ireland can i get parts for a tanaka THT
Try http://www.gardenmachinery.ie/
They have a list of dealers who may supply parts.
