This is the small faucet for filtered water. Have removed handle, but can't loosed for the life of me.
SOURCE: reverse osmosis causing poor water flow
cheak the main water flow and clean the machine inlet water filter
SOURCE: reverse osmosis water filter
Hi jennym123,
I'm Harvey the Master Plumber.
Your question is: You have a reverse osmosis water filter. The other day water production went from over a gallon of filtered water to 3/4 of a cup. You changed the filters thinking that may be the problem, but that did not solve anything. What else could be wrong with it?
This is a common problem. Can also be very frustrating. A small bit of debrie has been brought up by the flowing water and is stuck somewhere. As you can imagine this will restrict the flow. I would start with the on/off valve next to the cold water line first. Turn the water off first and take it apart checking for obstructions. Then work your way down checking the lines and any place you can. It's helpfull to have a bit of wire to probe with. If you turn it back on and the problem still persists then you missed it. Try again. Good luck.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: leaking Jado lavatory faucet
It is a rubber gasket that is leaking, Pull the cartridge with a cresent wrench. There will be a paking nut on the top of the cartridge where the handle connects. You should be able to remove this with a pair of pliers. There will be a rubber o-ring inside. Take that to the hardware to to find a replacement to it. It wont be hard to match they keep tons in stock at ace or lowes
SOURCE: Water filter system leaks at tap
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
SOURCE: Reverse osmosis faucet is leaking through the
when was the last time you checked the filter,it may be time to change it,if you have changed it you may have inserted it backwards.turn it over and try,if that still does not work the check valve at the filter feed line may be clogged,flush line this may fix your problem.good luck with your project.
Please disregard. The WD40 did the trick...just needed a bit longer to loosen up the fixture.
