Question about Lanier Office Equipment & Supplies
Lanier lp226cn wont recognize the new black cartridge
    Top Expert:
  • Lanier Master
  • 84,524 Answers
Are these new or refilled?
Posted on Nov 09, 2017
Testimonial: "That was a refill. We'll try a new cartridge. Thanks"
SOURCE:
drichards
  • 87 Answers
SOURCE: Lanier lp226cn
Hold the up and down arrows together for 10 seconds, and press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on. Try it. It is a fuser code, and it just might be dirty where the sensor touches.
Posted on Jun 07, 2008
SOURCE: I have a LAnier lp226cn
I have a lanier LD122 - error code is sc541
Posted on Nov 02, 2008
  • 4 Answers
SOURCE: epson do not recognizing new cartridges
Just posted this answer somewhere else...you probably touched the little green microchip on the cartridge. The oils in your hand prevent the printer from reading the cartridge. Hope this helps, sucks that you may have to buy a new cartridge though!
Posted on Aug 19, 2009
SOURCE: I have a Lanier LP226cn printer. Under the alert
Sorry, You do not need Black toner, you need a Black PCU (Photo Conductor Unit).
I have this same printer with the same warning.
Unfortunately, This unit seems to be rather expensive.
Good Luck
Posted on Mar 10, 2010
Ranglo
  • 1194 Answers
Thanks for using Fixya.
SC545 is a fuser warm up error.
Try resetting the error by holding the up and down arrows together for 10 seconds, and then press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on.
If the error is still there then you will have to take your device for repair.
Good luck and have a nice day.
Posted on Nov 10, 2010
In Lanier GX3000 I would like to print with black ink only. The printer displays to replace the three color ink cartridges.
The printer requires that all of its ink cartridges have ink before printing, the color ink cartridges will have to be replaced.
May 12, 2011 | Lanier Office Equipment & Supplies
I have a Lanier LP226cn printer. Under the alert status it is telling me to ''Prepare a New PCU'' and ''Replace CPU Black Soon'' I understand it means to replace my Black Toner soon as someone mentioned...
Good Luck
Mar 01, 2010 | Lanier Office Equipment & Supplies
Lanier LP020c laser colour printer horizontal lines
as if the cartridge is new.and colour is printing fine.then its not faulty cartridge or faulty printer.and yes you are absolutely right that it needs proper servicing.in the printer there are lens one lens is for colour and one lens is for black.if there is dust on the lens controlling black you will get lines and patches in black prinouts.but yes if the drum is got lines on it.that it will give same lines in the printouts.also you can get the drun serviced first before getting the printer serviced.a local printer repair shop does this drum servicing.also there comes a liquid to clean drum.you can get it from printer parts store.if want to do manually.but the shop will get it checked after serving in there printer.so it will be confirmed that is it drum or faulty /dusty lens in the printer. ----------- this will help.thanks.
Sep 20, 2009 | Lanier UNKNOWN
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
I have a lanier lp-138c that is giving me a black toner low message on brand new cartridges... Tried 3 different cartridges and at first they register and then to the toner low...
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Apr 14, 2009 | Lanier Office Equipment & Supplies
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Lanier lp226cn error code sc545 printer won't work, maybe a fuser error? new and has not been used enough for this to happen!!! Can I re-set this?
Jun 03, 2008 | Office Equipment & Supplies
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
113 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
