I lost the paper instructions and just need to see a print of that cause I forgot how to set the time after putting batteries into the remote transmitter before the receiver.
Hello Bob Loomis,
The joyous world of MODERN TECHNOLOGY...
FREE...
From MY meager research... MAKE & model are
paramount in FINDING ANY MEANINGFUL direction.
I am posting a sample from "MANUALSLIB.COM..
The INSTRUCTIONS are less important than the
WEBSITE... (Have a look)
Technoline WIRELESS 433 MHz WEATHER CLOCK Instruction Manual Page 5
On
ManualsLib Makes it easy to find manuals online
Hope this helps
Carnac the Magnificent
SOURCE: 2005 cadillac sts remote transmitter
This is the procedure for a reprogram of the remote's from the factory service manual, if it doesn't work then u may have a receiver issue.
Use this Procedure for Vehicles with
Driver Information Center Buttons
This information is in your Owners Manual in the
Drivers Information Center Section.
1. Insert Key and turn to ON position so you can access Driver Information Center
2. Press the vehicle information button until
PRESS TO RELEARN REMOTE KEY displays
3. Press the set/reset button until
REMOTE KEY LEARNING ACTIVE displays
4. Press and hold the lock and unlock buttons on the first keyless remote at the same
time for approximatley 15 seconds. A chime will sound indicating that the remote is
programmed.
5. To program additional remotes at this time repeat step 3.
This vehicle can have a maximum of eight remotes programmed.
6. To exit programming mode turn key off and remove key.
Test remote(s).
Use this Procedure for Vehicles without
Drivers Information Center Buttons
To access this display, the vehicle must be in Park (P) with key in the on position (as far
as you can go without cranking engine)
1. Press the trip odometer reset stem until RELEARN REMOTE KEY displays.
2. Press and hold the trip odometer reset stem for three seconds.
The message REMOTE KEY LEARNING ACTIVE will display
3. Press and hold the lock and unlock buttons on the first keyless remote at the same
time for approximately 15 seconds. A chime will sound indicating that the remote is
programmed.
4. To program additional remotes at this time repeat step 3.
5. To exit programming mode turn key off and remove key.
Test remote(s).
SOURCE: engine won't start until car sits for awhile after
replace the IAC or clean it. If it doesnt open when you try to start your engine it will not start, after it cools down it may work and let it start Idle Air Control Valve
SOURCE: I PUT IN A BRAND NEW BATTERY BUT WHEN THE CAR SITS
Hello chuck5227
It sounds like there is a draw on the system. To test for an electrical draw, turn off everything in the
car, remove the keys and close the doors. Open the hood, if the light under the hood works unplug it or remove the bulb to avoid a false read. Remove the negative battery terminal, take a 12V test
light clip one end to the batt. terminal and touch the other end to the batt. post. If it lights up theres
a draw. To isolate the draw pull the fuses one at a time, start with the interior light fuse so you don't
have to hold the button in. Remove+replace the fuses one at a time until the light go's out. the fuse
you removed controls the circuit with the draw. Check the wires-connections and switchs on that
circuit. Before you start pulling fuses take a picture of the fuse block with a digital or your cell phone camera, this way if somthing unintended falls off or out you'll know where it go's.
Hope this helps.
