HP DesignJet 750c InkJet Printer Logo
Posted on Nov 23, 2007
Error code 070028
AFTER INITIALIZING I GET THE STATUS READY IN THE WINDOW, THEN WHEN I TRY TO PRINT IGET SYSTEM ERROR 070020 IN THE WINDOW
Robert Michl
Level 1:
  • Contributor 26 Answers
  • Posted on Mar 24, 2008
Robert Michl
Contributor
Level 1:
Answers
26
Questions
Helped
15133
Points
33
The 070020 error means:
"One of the Drop Detection errors has occured - or, during the Drop Detection no drop was detected.
Pen checking is set to OFF.
* Perform the drop detect calibration,
* Troubleshoot the catridges and the drop detector.
* If required, replaced the service station, .
* Check the cable assembly and the main PCA.
How do I solve error code 11-114 on my samsung CLX6260nd printer
Recovery: If the LReady or Hsync error happens, the paper is exited before the error code is initiated. .... You also can resolve the error with the guideline from the computers's Samsung Printing Status window.
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
7helpful
3answers
Error code 0xc18a0201
Hi.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
"Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
11helpful
WON'T PRINT IN WINDOW IT SAYS INK SYSTEM HAS FAILED ERROR:OXC18A0001
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Error code Oxc18a0001 I tried unplugging and replugging after 2 minutes. Removed cartridges. After turning back on error code still there.
The following steps are the summary of a conversation with HP Tech Support:
1. Press and hold "left arrow" key 2. Press the "setup" key and release both keys
4.Press and release the right arrow button until the display says "System Configuration Menu". 2.Press and release the "OK" button.
5.Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6.Press and release the "OK" button.
7.Display should say "Hardware failure status: Clear. Press OK to clear".
8.Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9.Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10.Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11.Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12.Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13.If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15.If the error is still there, or reoccurs the printer is already defective.
Let me know how you make out, and feel free to leave feedback. Thanks!
2answers
Ink system failed. Error: 0YC18a0201
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn the all-in-one on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.I hope this information be helpful. Regards
33helpful
3answers
Error:oxc18a0206
- Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
1helpful
Can print...ink system failure - followed process but it wont wor
14helpful
"Wrong Cartridges" Error HP C5180 now Failed ink system.
Please perform the following steps:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
C. - Press and release the “OK” button
Display should say “Support” and display the FW rev (something like R0616R)
Now, perform the following instructions:
1. Press and release the right arrow button until the displaysays “System Configuration Menu” 2. Press and release the “OK” button.3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.5. Display should say “Hardware failure status: Clear. Press OK to clear”.6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. 11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.13. If the error is still there, or reoccurs replace the unit.
k24674
Grand Canyon Tech
Grand Canyon Tech
