Turned on, battery charged, meter shows full, fuses all good, circuit breaker is fine, it is in gear, when throttle pulled, nothing engages - short time later horn beeps. Scooter just quit while traveling down a street - no indication why it would stop.
Hi it's possible the control box down timer was activated check if freewheel lever is in drive remove key & wait a few minutes replace key & turn on cheers.
Testimonial: "Appreciate the answer, but no joy. Remember, this happened while scooter was in use - suddenly freezes then never to re-engage...mysterious! (I tried your solution at once)"
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
SOURCE: I have a Pride Legnd..the scooter started loseing
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Testimonial: "Any insight to a problem is a positive step."
SOURCE: where and how do I replace my battery for my pride
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY! Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Yes very strange are there any fault beep code's usually the code beeps start from 2 up to 9 beeps .
Yes, it beeps 9 times. So I'm thinking I probably have to disassemble the controller head. Argh! I am communicating with Pride now so I will see if they have a solution.
