Question about New Bright Toys
New bright greatland holiday express train wheels won't turn
SOURCE:
  • 14 Answers
SOURCE: instructions
Not sure what instructions you need, but the setup is very simple.
1. Put your track together
2. Attach the track power connector by slipping it under the track and pushing, then lift up the other side. This will make the two metal contacts connect to the track.
3. Plug the connector from the power pack into the track module (It should only go one way)
4. Plug the control box (looks like a telephone cord) into the track module, Will only go one way
5. Place the locomotive on the track.
6. Place the Treetop Tender on the track (you need both to make it run)
7. Connect the large connector from the treetop tender to the loco
8. Turn on the command module and press forward ...
You should now be running in circles ...
Hope this helps...
Posted on Dec 15, 2009
  • 14 Answers
SOURCE: Where can I buy a track clip for my New Bright
http://www.newbright.com/
New Bright does not offer any replacement or repair parts for thier products.
They have a 60 day replacement warranty, but after that, you are on your own.
Posted on Dec 16, 2009
  • 14 Answers
SOURCE: New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
SOURCE: Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Posted on Dec 19, 2009
Testimonial: "Thank you! Now... how do you keep it on the track? :O)"
  • 5 Answers
SOURCE: an electricalroblem with Holiday Express train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
NEED SCHEMATICS ON A NEW BRIGHT HOLIDAY TRAIN384. tRIED LUBING AND DRIVE WHEELS CAME LOOSE
sadly toy companies do not provide schematics. fixers have to figure them out for their selves
Oct 08, 2016 | New Bright 384 Holiday Express Animated...
1994 Greatland Holiday Express train set. Where can I get at least two curved tracks?
There are places online that sell that track. It's pretty expensive. Measure the distance between the rails to get the correct track. Greatland may have the track, but if they don't, then look online for other places.
Dec 17, 2015 | MIA Toys
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
My greatland holiday express train doesnt run how can i fix it?
I am now having this same problem as well. PLease help
Dec 09, 2012 | Toys
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
Dec 18, 2009 | New Bright Small Holiday Express Train
Dec 22, 2008 | New Bright 384 Holiday Express Animated...
Toys Logo
124 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
