SOURCE: i have a moultrie 4.0 megapixel trail cam I have a
none. A # PRECEEDED BY E(event) is telling you the cam picked up, in this case, 756 events...not necessarily did it capture that many pics, but the sensor came on 756 times...had the critter stuck around past the delay setting, then you should have gotten a pic.
SOURCE: Need to reset security code for Moultrie I60
Moultrie has a "no exception" rule...original receipt, I presume from authorized dealer; $25, to cover reprogramming and shipping, and they will reset pass code to default...
Only other solution is to find a defective i60 and hope it doesnt have a pass code entered. Then swap boards.
SOURCE: moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
SOURCE: moultrie m100 game camera security code reset
the override code is the last code you put in. put it in exactly and hit enter. it worked for my boyfriends moultrie 100 camera.
