Leviton 6161 is shown on Leviton as 500 watt incandescent-only 4-level dimmer that cannot control a fan.
If this is a ceiling fan and light, then search for fan light dimmer, or fan control,
If this is bathroom fan-light installation, you are needing a countdown timer rated for both bulb and fan... which will require Neutral wire...
Different timer choices with manuals appear following link:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#Leviton
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: timer counts down, light turns on, no fan, no heat.
Hi bboelter,
When you say "no heat", I take that to mean it's not
heating the food up. When a microwave suddenly stops heating food, but
still appears to run (the control electronics and light are usually a separate circuit), it's usually a defective/dead magnetron. Given the age of the oven (13+years), this is also points toward the magnetron. The fan _may_ or may not be on the same circuit as the magnetron, that's hard to say without a wiring diagram or schematic.
Prices
for replacement/repair will vary, you will need to find out what that
service costs in your area before having enough information to
decide on repair or replacement. If you tell the repairer that you suspect the magnetron, they should be able to quote you a fairly accurate estimate.
When my first microwave lost
it's magnetron (~20 yrs ago), it was 5 years old at the time, and the
cost of buying a new oven was only a little more than the repair - but
I had the repair done anyhow. Since then, we've replaced the entire
oven instead (twice). Newer ones may have more power/less energy
wastage, etc.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
SOURCE: voltage to evap fan 94v not working runs slow @ 120v
Hi, I deal with evaporator motors on a day to day basis.If the motor is running but not up to full speed, the inner windings of the motor are going out. If the motor runs as you say, is it getting only 94 volts to it? If this is the case, check the incoming voltage to the unit itself. Check to see on the schematics what is between the motor where you may be loosing your voltage. Defrost thermostat, or timer. Check power to the timer first and get back to me. The defrost thermostat supplies power to the fan when the evaporator temperature gets cold enough and the contacts will close and send power to one side of the motor. If it is going bad, it will cause you to loose part or all of the voltage. If you have a meter, check this. It is round and sealed with 2 terminals on it. If it is cold enough, you can check the leads to ground and see if you are getting less then 120 volts coming out the motor side. If so, replace the thermostat. Please keep me posted.
Sincerely,
Shastalaker7
PS Be safe around electricity. Also, this defrost stat snaps around a evap. line.
SOURCE: Need timer switch for millivolt gas fireplace
These guys are a division of Monessen, a gas fireplace manufacturer, and have a variety of millivolt switches, remotes and thermostats.
http://www.ambienttechnologies.com/
SOURCE: I purchased the 6161T Preset Electronic Timer
The timer you have purchased will not work for 3-way switching.
We know this because the wires are color-coded.
And you have 2 black wires.
Good job providing that information so I can see what you have.
Both your timer wires are black, and that tells the electrician that the timer is made for single-pole only.
That being said, there are timers that have the same color wires as your 3-way switch, but the timer has to say it works for 3-way circuit.
Usually the instruction sheet or package will say, 'for single-pole.'
Or it will say, 'for single-pole and 3-way.'
1) Aube makes programmable 7-day timers for a 3-way installation.
But this timer is not for countdown.
2) I am searching the web for a 3-way countdown timers, and Levition offers one, but they require you to replace both 3-way switches and then install a 'master-and-remote' combo.
This means each timer is a different model number.
If you want help sorting out that purchase, add a comment and I will research the Levition site.
3) Smarthome sells a countdown timer for 3-way circuits.
It appears to be exactly the product you are wanting.
The product has 95 ratings with 4-1/2 stars
http://www.smarthome.com/2476ST/SwitchLinc-Timer-INSTEON-Countdown-Wall-Switch-Timer-Non-Dimming-White/p.aspx
The product manual is right there on the Smarthome page.
They provide an installation video.
Smarthome is very customer friendly.
I specialize in timers and electrical devices, but I do not know the product shown above.
However I can help you install it.
Add a comment and I will help further.
SOURCE: I installed a Leviton 1000W/20A 1HP-120V timer to
I think the timing device has failed.
Most of these devices come with 1 year limited warranty, so you can exchange for new one.
I usually buy new one, and then return old one as if it was just purchased.
I test timers.
One thing you can check: buy circuit analyzer at home center and plug into receptacle on same circuit.
If circuit is not clean, this will affect electronic devices and shorten lifespan, causing operation failure.
If there is a fault somewhere, you can use multimeter from home center and start at end of circuit and work back through each box and light fixture.
Add a comment for more free help.
Also take advantage of fixya phone service.
