Plumbing Logo
K
Karen Posted on Nov 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touch less delta faucet not working new install yesterday,no problems new battery’s. Now no water flow. Put in by a plumber.
  • David Ellis Rhea Nov 08, 2017
    Hi Karen , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    You will need to work this out with your plumber. There is no wway we can help.
  • Mike Newman
    Mike Newman Mar 12, 2018
    Make sure the battery pack is not touching anything metal and the batteries are put in the correct polarity.
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Dec 04, 2017
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
79012
Points
573
If you're sure the water valves are turned on, try removing and cleaning the aerator.
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Nov 08, 2017
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018725
Points
74913
Under warranty. Call plumber back
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2697231
Points
29284
Get hold of the plumber and have him repair the faucet under warranty.
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 05, 2008
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 09, 2008
SOURCE: Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Anonymous
  • 146 Answers
  • Posted on Jun 26, 2009
SOURCE: Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
jpintore
  • 129 Answers
  • Posted on Oct 05, 2009
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
2helpful
2answers
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
Plumber installed a delta multichoice valve trim 17 two years ago. The water temperature knob is getting harder to turn again. It happened a year ago too and the plumber put in a new cartirdge saying...
not all that familiar with your particular faucet. but in my experience, most plumbers dont put grease on the valves when installing them . the factory just uses enough grease to get the valve in the faucet. if you have extremely hot water and use it . it wont take to long for it to cause this problem.. just an opinion. i cant imagine how the buildings shutoff could have anything to do with your problem.
We just installed the new delta pilar touch in our new home last week and the red light is already on and no water, does that mean the batteries are done already? And will the water not work manually even...
Levina, I recommend you call Delta's Customer Service Department and explain about the red light. If the batteries were new when they were installed, they should still be good. I had a problem with our Delta Pilar and when I called, the customer service representative was very helpful and solved the problem while we were talking. Good luck and please post back to let us know what happened.
Carly
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Hot water side suddenly has less flow and only warm water.
The stem and washers need to be replaced.
They are what controll the water mix internally. You can do it yourself typically for 10 to 15 bucks or pay a plumber $75 to $125 to rebuild it.
Delta parts can be purchased at any plumbing supply warehouse, hardware stores or Lowes/HD stores.
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
2helpful
  2. Remove handle.
  3. Remove top cap.
Top Delta Plumbing Experts
john h
vince
Paul Carew
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
