be sure to clear the catche on all items downloaded, facebook and messenger takes up alot of storage and makes your system run slow unless you move messenger over to the sd card, be sure to have an sd card,be sure to install virus protection to clean up files and trash left over from uninstalled apps,, you cud have a virus clean it with virus protection, any upgrades can be purchased here>> Discount Bargain Prices
You need to run the "applications manager".
If you open the icon labeled "Apps", "setting should be in there on one of the pages.
Once you are in "Settings", scroll down to the "phone" section.
There you will find "Applications", open "Applications".
The top of the list should be the "Applications manager".
You will see a list of "All apps", Some of them came pre- installed on your Galaxy Tab, and can't be deleted. But they can be forced to stop and disabled.
Apps that you have installed that you want to delete can be
"Uninstalled".
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
The internal memory cards of some Android devices are partitioned for app storage and installation. Some of them have partitions that are quite small such as one Gigabyte or smaller. The remainder of the storage cannot be used for apps.
If it keeps saying not enough memory space then chances are the app partition is full. The only way to free up some space is to uninstall some apps that are stored there but not being used. You can see which apps can be uninstalled in Settings > Apps and look at them one by one to see if an uninstall option is listed. Simply click *uninstall* to remove them from the app storage partition. This will free up some extra space for some new apps or for updates to older apps you still like and use.
Also some of the apps might show an option to move them to an external SD card (if your device has a slot for one and if an SD card in inserted therein). Do move any and all to the external SD card of you have that option as that will also free up that space from the internal SD card.
Some tablets have limited space for apps. If you have internal memory of 8 gigabytes, for example, perhaps only about one gigabyte of that is partitioned for app storage on some devices. When that app storage becomes full, nothing more will be able to download and install.
You can go into Settings> Storage and examine the top bar graph to see if the app storage partition is full. If it's full you will be able to free up some space by uninstalling some apps you don't want or never use.
Go into you applications and decide upon which apps you do not need our use. Select the app, and then uninstall. Run a cleaner app afterwards to ensure tablet is optimized.
You might want to free up internal storage space on your android tablet. You can do this by moving some apps to an SD card that you have installed. Go to your app drawer, tap and hold on an app, and drag it to "App Info". Then tap move to SD card. Another way to free up space is to uninstall apps that you don't use anymore. If that still doesn't work, try installing a storage cleaning app. I would recommend SD Maid by darken. Hope this helped!
That system warning relates to available application space. For some reason Archos only devoted ~128 MB for applications, so you can fill that up pretty fast. You'll need to:
uninstall applications (settings, Applications, Manage Applications, then select and uninstall some)
or
move some applications to "internal storage", this transfers some of the space they're taking to the internal storage on your Archos. Again you'll go to Settings, Applications, then Manage Applications. From the list of applications select some of the larger ones and you may see a "move to internal storage" option. Some apps have this, some don't.
