SOURCE: Maytag Nepture washer error code:
this is a code for too much soap is being used add vinager to wash tub to eliminate residual soap and run an empty cycle to rinse out. then use only 1 oz of HE type detergent only per load
SOURCE: i have a code that's
It means you use too much soap and or the wrong type of soap.
Use only H E soap and the amount specified.
Remove the filter at the bottom front of the machine and clean it out.
Replace the filter and run the machine.
Use only the correct soap and correct amount to avoid future problems like this.
