Question about Nortel Lands Phones
Changed the time on our Nortel Networks phone system several times, but it keeps reverting back to the old time (1 hour ahead). This happens when a call comes in. What is happening? How do I fix this?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
consultel1
george peters
  • 860 Answers
SOURCE: how to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Posted on Mar 19, 2010
Everyday i reprogram the time to current pacific time. sometime during the day and or night, it reverts back an hour
the fault is from the battery of your phone. There is a battery in the phone that keeps the time going, this battery is weak, that's why each time you set your time, it reverts back again because the battery is weak.
Its the same thing that happens to a wall clock, when the battery of a wall clock is weak, it begins to draw the time back.
Also, another cause of this problem is if the phone is turn off and removed from power, this can affect the time.
I hope you understand my explanation.
Good luck.
Jun 09, 2010 | Inter-Tel Encore Phone
How to change the time one hour ahead
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
My phone shows the wrong time and date, how do I reprogram it (I have no manual) sorry, its a Nortel Networks NT8B27JAAA..
5.- Press softkey "CHANGE"
7.- Select AM or PM
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
15.- Press softkey "CHANGE"
16.- Enter month
18.- Press softkey "CHANGE"
19.- Enter day
Jan 05, 2010 | Lands Phones
Change Time
THe older norstar systems you had to go into programming to change time and on the newer systems press feature * time on your phone and follow the prompts. On the older systems go in to programming press feature ** 266344 (config) then pswd 23646 (admin) on your key pad this gets you into programming press next until you get to change time. You need an overlay which can with your phone system manual. If need more info please ask agian hope this helps.
Nov 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
My thinkpad keeps reverting back to an old IP
go to your prefered wireless networks and delete the old entry this way it can not revert back to it
Jul 12, 2009 | IBM ThinkPad T40 2373 Notebook
Step 1
Mar 11, 2009 | Lands Phones
Time & Date
the console takes its time from the clock in the system .its the system time that is incorrect and needs modification in overlay 2.this can occur when moving from summer time to winter time and daylight savings not setup in your system.
Nov 03, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Changing time on Nortel networks Phone system
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
Apr 15, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
47 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
