Plumbing Logo
T
TMC1 Posted on Nov 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove the escutcheon plate for a Kohler Alterna shower trim piece
There is no set screw or other obvious way to remove the handle to get to the stem. Kohler says item is no longer available and advice on removing does not work. Have photo if it would help
Robert Kulkofsky
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Nov 12, 2017
Robert Kulkofsky
Expert
Level 2:
Sergeant:
Answers
200
Questions
5
Helped
47330
Points
595
They are normally held on with two screws to the valve.
5 Related Answers
Anonymous
  • 49 Answers
  • Posted on Jan 23, 2009
SOURCE: grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 23, 2009
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Anonymous
  • 195 Answers
  • Posted on Mar 16, 2009
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Donni Steen
  • 687 Answers
  • Posted on Apr 10, 2009
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Anonymous
  • 62 Answers
  • Posted on Jun 05, 2009
SOURCE: I cannot for the life of me figure out how to remove the cartridge from our single handled shower faucet handle. Best I can figure it's a Moen T2449 or T3132.
Click on this link:
http://www.moen.com/buyMoen/buyparts/Parts.cfm?sku_refno=426183
Then click on illustrated parts diagram.
Remove the temperature limit stop kit, the stop tube and then the u-clip. Pull cartridge straight out (It could be tuff...you may need to buy a moen cartridge puller tool)
Be sure to turn the water off first!
1helpful
How do you remove KOHLER K-T312 shower mixer cover plate?
give this a shot remove the control knob then there should be a stem cover it usually keeps pressure on the plate when the knob is placed on it so remove the stem cover make sure if it has ben caulked as they usuall have a gasket that is stuck to the wall but if the gasket is loose and there is no caulk it should come right off as there is no plave for any set screws or fastening screws also Kohler has a great website www.kohler.com put the model number or match it up to the pictures and check out the info I have two in my bathrooms and I just did what i told you to do and it came right off.
Apr 29, 2014 • Home
2answers
I have Kohler single handle shower, but the handle does not have a screw to remove it. How do I remove the handle. The handle was installed in the house in 1999. Thank you.
Ok I am take a stab at this. If it is a L shaped handle it is not steel but an aloy and at the end of the long part of the handle is a end cap that either screws off or pops out when pry on. The set screw should be in the handle under that.
If that is not true then the set screw has to be somewhere around the base of the handle near the shower cover plate maybe headen under a little cover that would look like a small push-in cap.
Feb 05, 2011 • Plumbing
How to remove the cover plate from a triton t80 shower
Remove handle by locating set screw. Escutcheon (cover plate ) screws are now accessible to be removed.
2helpful
How to remove door panel on a 1985 cadillac eldorado
Very easy! One tool that will save you a lot of headache and anger can be bought at any auto parts store and looks like this:
You use this tool to pop loose the plastic fastners that are attached to the door panel edges.
But first, remove all screws...remove the door handle cup, pop loose the master door/window stich assmbly, etc. Very simple process....takes less than 10 minutes.
Door Panel
  1. Remove all door inside handles.
  2. Remove the door inside locking rod knob.
  3. On styles with door pull handles, remove the screws inserted through the handle into the door panel.
  4. On styles with remote control mirror assemblies, remove the remote mirror escutcheon and disengage the end of the mirror control cable from the escutcheon.
  5. On styles equipped with switch cover plate in the door armrest, remove the screws securing the cover plate, then disconnect the switches and cigar lighter, if so equipped, from the harness connectors.
  6. Remove the remote control cover plates and remove the exposed screws securing the cover plate to the door inner panel.
  7. On styles with integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. On some styles it may be necessary to remove the screws behind the armrest deflector or courtesy lamp remote control cover plate. On styles with armrest applied after the door trim installation, remove the armrest to door inner panel attaching screws.
  8. On styles with with two piece trim panels, disengage the retainer clips at the front and rear of the upper trim panel. Remove the upper trim panel by lifting upward and sliding slightly rearward to disengage the the front door inner panel at the beltline.
  9. On styles with electric switches located in the door trim panel, disconnect the wire harness at the switch assembly.
  10. To remove the lower trim panel, remove the attaching screws along the upper edge of the lower trim panel. Then starting at a lower corner, insert a pry type tool between the door inner panel and the trim panel and disengage the retaining clips down both sides and across the bottom. On styles with courtesy lamps or reading lamps located in the trim panel, disconnect the wire harness at the lamp assembly.
  11. On styles with one piece trim panels, remove all the clips around the perimeter of the trim panel. Push the trim panel downward and outboard to disengage it from the door inner panel at the beltline. Disconnect any courtesy lamp wire harnesses, if so equipped and remove the trim panel from the door.
  12. Installation is the reverse of removal. On styles with adjustable trim supports at the beltline, the door trim panel can be adjusted in or out so as not to restrict door window operation
How to remove diverter cartridge in shower 1 handle
Follow these steps.
  1. Remove Set Screw in handle and remove handle.
  2. Remove the 2 screws from the handle housing and remove the housing and escutcheon from escutcheon adapter plate.
  3. Remove valve stem screw and valve stem coupling.
  4. Remove the escutcheon adapter screws and escutcheon adapter.
  5. Using a pair of pliers pull the cartridge retaining clip out of the valve.
  6. Grasp the cartridge by the stem and pull out.
I hope this is helpful to you, please rate if this answer was of any help. Good Luck and have a great weekend.
2helpful
How do I remove the door panel and replace the inside door handle
PLEASE DON'T FORGET TO RATE!!
Door Panel
  1. Remove the door handles and the locking knob from the inside of the doors.
If equipped with screw retained door pull handles, remove the screws through the handle into the door inner panel.
  1. If equipped with remote control mirrors, remove the remote mirror escutcheon, then disengage the end of the mirror control cable from the escutcheon.
Door lock remote control handle
Removing the clip from inside the door handle
3. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switches and the cigar lighter (if equipped) from the electrical harness.
4. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
View of the armrest switch cover plate and remove mirror cable attachment
  1. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
If equipped with electric switches in the door trim panel, disengage the electrical connectors from the switch assembly.
  1. Along the upper edge of the lower trim panel, remove the mounting screws. At the lower edge of the panel, insert tool No. BT-7323A between the inner panel and the trim panel, then disengage the retaining clips from around the outer perimeter. To remove the lower panel, push the panel down and outward to disengage it from the door.
If equipped with courtesy lights, disconnect the wiring harness.
  1. If equipped with an insulator pad glued to the door inner panel, remove the pad (with a putty knife) by separating it from the inner panel.
To install:
If replacing the inner pad to the door inner panel, use 3M General Trim Adhesive No. 8080, glue it to the panel.
  1. If removed, glue a new inner pad to the door inner panel.
If equipped with courtesy lights, connect the wiring harness.
Exploded view of the window regulator handle
Exploded view of the door trim panel
  1. Engage the retaining clips around the edge of the lower trim panel, then install mounting screws.
If equipped with electric switches in the door trim panel, engage the electrical connectors to the switch assembly.
  1. If equipped with two-piece trim panels, engage the retainer clips to the front and the rear of the upper trim panel.
  2. If equipped with an integral armrest, install the retaining screws.
  3. If equipped with a switch cover plate in the door armrest, engage the switches and cigar lighter (if equipped) harness connectors, then install the cover plate and secure using the plate screws.
  4. If equipped with remote control mirrors, engage the control cable, then install the remote mirror escutcheon.
If equipped, install the pull handle screws through the handle into the door inner panel.
  1. Install the door handles and the locking knob to the inside of the doors.
Exploded view of the 2-piece door trim
  1. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switch
  1. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
  2. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
To install:
  3. If equipped with a switch cover plate in the door armrest, engage the switch harness connector, then install the cover plate and secure using the plate screws.
1helpful
How to disassemble a Kholer Rite-Temp Shower Faucet to repair a dripping shower head. It has a one handle design with no obvious set screws. Any where to look at a scamatic to show how it's put together?
Call Kohler, most of their products have lifetime guarantees also come with diagram. Look for a set screw either beneath (underside) the handle or under a center cap on the handle. Some are obvious, others appear to be part of the design, raised outline, temp indicators etc.
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
How do you remove the door panels on a 1995 mercury villager
http://autos.groups.yahoo.com/group/villagerquest/
you have to remove the cup behind the door handle. rmove screws aroun the door pull. get a screw driver and pry the trim panel away from the door carefully. There is a plastic christmas tree clip every 6 inches. when the bottom & sides are free, lift up the trim panel to get it out of the track at the base of the window.
Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connections.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  1. Remove the front door trim panel.
1helpful
The window fell off it rollers
  12. Installation is the reverse of removal. On styles with adjustable trim supports at the beltline, the door trim panel can be adjusted in or out so as not to restrict door window operation.
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
