They have a throttle body fuel injected engine. If its hard starting then smokes usually that indicates pour fuel quality or something wrong with fuel system.
SOURCE: 1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
SOURCE: Carburetor adjustments for FE250D engine in a John Deere Gator
generic carb adjustment, any adjusting screws, turn them all the way in the back out 1 turn. run the motor and adjust
SOURCE: 1997 Saturn SL1 very hard to start
jlwhelen,
I will suggest that perhaps the blue smoke is not purely oil. It sounds like you may have an ignition problem where the engine has a hard time firing until warmed. The blue smoke may be, at least in part, unspent fuel. I realize that a warm engine that uses oil will smoke blue, but excessively rich conditions on startup can result in a similar effect. If the choke circuit is delivering a little extra fuel from a dirty injector, the problem may be worse when starting from cold.
To remedy this, I would suggest a simple replacement of plugs and wires, as well as a fuel injector cleaner through the tank. I would bet money that these simple maintenance points would solve your problem.
Lucky
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: John Deere Gator XUV 2008 oil in gas
I know exactly the problem. I work for a John Deere dealership and have seen this problem before. It is called short-tripping. When a machine is first started, gas does leak into the cylinder and crankcase past the rings--normal--simulates leaving the choke on too long with a carburetor engine.. As the engine temperature rises, the gas in the oil is burned off and there really isn't a problem. When you take short trips or do not let the engine run to get it up to temperature, the gas in the crankcase does not get burned off and will accumulate over time. Make sure the machine is getting up to operating temperature and this could take up to 20 minutes if the ambient air temp is low. Feel free to e-mail at [email protected] with further questions
