You could only change the region code for several times. You could also play your discs on a region free player so that you could be free from region code trouble. You could try Leawo Blu-ray Player which is a free program for Windows and Mac.
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
SOURCE: Making my DVD Player Region Free
It is not a permanent hack, you will have to to it over for every out of region movie you put in.
1. When "REGION CODE ERROR" shows on screen after you've input your wrong-region DVD you push "ON SCREEN".
2. When the DVD-menu is showing push "ON SCREEN" again and another DVD-menu will appear.
3. Move the arrow over to the clock and press enter. The menu asks for "TIME" and you write 0:00:00 and push enter.
4. You will now see the menu for the movie. Remove the DVD-menu by pushing "ON SCREEN" once. You can now watch the movie.
SOURCE: Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens.
2. Press the following buttons in sequence: 2, 8, 1, 2.
3. TV displays "Region 2"
4. Press the Enter button on the remote until code changes to 9
5. Press the Open/Close on the remote. DVD tray closes.
6. Press Power on the remote control.
Now code free...
SOURCE: Region code for Sony BDP S300
http://www.hometheaterinfo.com/dvd3.htm
http://www.dvdregionhacks.com/
Testimonial: "I still couldn't get the info i needed from the links, so unless i'm missing something the advice wasn't helpful."
