Televison & Video Logo
C
Claire Stearns Posted on Nov 05, 2017
How do I hook this tv up with a cable box? - Televison & Video
akash gupta
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 20 Answers
  • Posted on Nov 05, 2017
akash gupta
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
20
Questions
0
Helped
3124
Points
63
  1. Turn off and unplug the TV and cable box. ...
  2. Hook up one end of a coaxial cable to the cable wall outlet and the other end of this cable to the back of the cable box using the "In" jack.
  3. Connect one end of the RCA audio/video cable to the back of the cable box using the "Audio/Video Out" jacks.
2 Related Answers
Anonymous
  • 2992 Answers
  • Posted on Mar 01, 2009
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
Robert
  • 176 Answers
  • Posted on Jan 20, 2010
SOURCE: trying to hook up magnavoc Dv220mw9 to my cable box & tv
Sorry, looks like it didn't load right with that last solution. Let me try again....
CONNECTING VCR
If this doesn't get it let me know I will try to walk you through it further.
Good Luck....
2answers
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Tv won't read the cable when hooked to the cable wire without cable box
Hello, Mary -
Your cable TV provider probably requires all TVs accessing the cable service to have their own cable converter boxes.
Note: An extra cable converter box will probably cost an additional monthly fee.
We have AT&T Uverse as our cable TV provider and need a cable converter for each TV.
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of...
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
1helpful
Trying to hook up magnavoc Dv220mw9 to my cable box & tv
CONNECTING VCR
Good Luck....
2helpful
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
2helpful
3answers
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
