Carolyn Thacker Posted on Nov 05, 2017
How to set clock ON GE- JB860SJ1SS - Audio Players & Recorders
Ann Bckstrm
Level 1:
Habit-Forming:
New Friend:
  • Contributor 25 Answers
  • Posted on Nov 05, 2017
Ann Bckstrm
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
25
Questions
0
Helped
5476
Points
60
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
I cannot get the GE microwave clock to set! Help?
To set the clock on most GE microwaves:
1 With the microwave door closed, press CLOCK.
2 Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
3 On some newer models, indicate AM or PM for morning or evening.
4 Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
1helpful
How to set clock on GE DOUBLE OVEN STOVE MODEL #JB860SJ1SS
To set the clock on the JB860SJ1SS, press and hold the 9 and 0 keypads simultaneously for 3 seconds (or a bit longer). Then type the current time using the keypad. Press Start to save the current time. This is shown on page 13 of the manual; see item 7 Clock.
Sears Parts Direct has the manual available here: https://www.searspartsdirect.com/partsdirect/user-manuals/JB860SJ1SS-GE-ELECTRIC%20RANGE-manual . The direct link to download the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1508037L.pdf .
I hope this helps.
Nov 05, 2017 • GE Ovens
Set the clock to DST, on my GE JRP20 B wall oven
set the clock to a new time:
TIMER/CLOCK Pad
To set the clock, touch this pad twice and hold 3
seconds and then touch the + and - pads. The
time of day will flash in the display when the
oven is first turned on
Mar 22, 2017 • GE Home
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
1helpful
Set the hour on clock on GE electric stove
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
GE 7-4894A Clock radio manual
findally got the instruction for my ge auto clock set thak you so much
20helpful
Set the time? ge model #75350.
Download the manual here:
http://www.devicemanuals.com/guide/CD%20Player/RCA/RCA-75350-User-Manual-==TVRJMk1UZ3k=.html
Or open the battery compartment on the right side and press the clock button, >> or << to set time, and press clock button again to save.
1helpful
How do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
 Grubhead
Grubhead
SmartAviator
SmartAviator
