I shut off the power and turn back on to see if it well resent the unit. Nothing happen. I have no reading or lights on the control panel
You have to check electricity coming to the oven. It is 3 wire coming to the oven. Red, white and black. Between red and black you should have 240V. Between white and red - 120V, between white and black - 120V.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: frigidaire single wall oven
We had a similar problem. When the repair person arrived he turned of the electicity to the oven then turned it back on. The control panel is a computer and he rebooted it.
SOURCE: Oven Light won't shut off
Amazing, I had the same problem, was told the same thing, even quoted the same amount! There must be a playbook with stupid answers by repair people. Anyhow, here is how I unlocked my oven: "Press and hold the 'Lock' button for 3 seconds then let go and it should unlock in about a minute." Hope this works for you. Don
SOURCE: I have a GE Single Wall electric
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
SOURCE: Describe your Profile JTP18 Electric
Hi The issue is with the touchpad assembly as everything else
seems to be working fine and it should be replaced. Hope this helps...please
post back for further assistance. Daniel
