Question about Leisure Kitchen Ranges
I have a 101 leisure cook master and need to change the fan element how do I do this? Does is have to be removed from the back? Thanks
SOURCE:
  • 3 Answers
SOURCE: Neff fan element
All of this can be done with the oven in situ. Take the back off if you like, but its un-necessary, dirty and time consuming. So here we go: Power off at mains. Remove 4 screws holding plate which guards the fan. You will be faced with the fan partially obscuring the top element retaining screw. At the centre of the fan spindle is a reverse threaded nut. WD40 the nut. Wait a minute or so and using a socket wrench and a flick of the wrist, the reverse thread nut should losen v easily. Having mastered the lock nut, tap the washer and it should become loose enough to remove by hand. If not, it just needs a little gentle persuasion with a flat head screwdriver where it sits on the fan itself. The grime will loosen and it will pop off. Squirt some WD40 onto the fan spindle, and wait a couple of minutes. Ignore any advice to lock onto the threaded spindle because if you damage it, your relatively cheap repair will become pretty expensive. Simply use a locking mole grip on the fan itself where the locking nut sits against it and pull and twist gently away from the spindle. You will be surprised how easy this is. Very little chance of damage. You can then access all 5 element retaining screws. Gently lever out the left foot of the element from the oven housing. Remove the spade connectors from the old element. Reversal of these instructions to fit the new element. Restore mains power. Reset clock or main oven will not work.
image_icon_name.gifSi Boon
image_icon_date.gifSeptember 2008
Posted on Sep 23, 2008
  • 343 Answers
SOURCE: Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Posted on Apr 24, 2010
SOURCE: Have a Leisure roma 100 cooker model number
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Posted on Jul 24, 2010
BElectric
  • 1140 Answers
SOURCE: leisure rangemaster 110 fan oven
There are 3 possibilities:
Faulty thermostat
Faulty wiring
Faulty oven control switch
Thermostats fail more often in the closed position which means your oven will overheat so I'd test the wiring first. You'll need an Ohm meter to do this. TURN THE POWER OFF FIRST, expose the element and switch then trace the wires from the live and neutral terminals on the element back to the switch. If you can't trace them, make a note of their colours (at the element end) and test for continuity/resistance with wires of the same diameter and colour at the switch. You should get a reading of zero ohms if you have good continuity.
The easiest way to check the switch is visually. Make a note of the wiring colours and their positions on the switch terminals, disconnect them and remove the switch. See if anything looks broken or the
Some thermostats can be disassembled and inspected, but I don't recommend it unless you know what you're doing. The gap between the thermostat switch contacts needs to be precise or the oven wont heat to the correct temperate.
If you can establish that the wiring and switch are OK, try replacing the thermostat.
Posted on Oct 15, 2010
  • 827 Answers
SOURCE: I have a Leisure Alto
Drill out the rivets and replace with screws.. you may need a right angle drill or right angle drill adapter to fit the drill in there. Always take care and be sure to FIRST cut off ALL power to the unit and give it a good once over with your eyes to determine where the drill bit would follow through to prior to drilling - just to be sure you are not going to hit any other critical component...
Posted on Jan 05, 2011
My leisure 101 fan oven is not heating up the fan is coming on but not getting hot
Probable element has failed. Replace the element after testing it of course.
May 06, 2017 | Ovens
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
Main oven not no heat.thought maybe heating element. tried to take element out from inside oven but seem I may need to take back cover off as it seems the two screws on one side come in from there.
yes your doing fine, usually heating element are sturdy and seldom busted. try to follow the wiring inside and locate the thermal fuse that is installed inline with the wiring,have it replaced
Sep 03, 2015 | Leisure GRB6CVR Electric Cooker with...
Have a electric cooker model nut grb6cvk no heat from main oven everything else working
Oven heater element has died. Get the serial numbers etc off the plate on the back or the handbook, go online to appliance spares sites and see if they carry an element. If you don't know how, get a good DIYer or appliance tech to change it. You could get them to check the element for continuity first?
Nov 15, 2014 | Leisure GRB6CVK Electric Cooker with...
I have a LEISURE COOKMASTER 101, it has a clock with buttons below that include a BELL, COOKING POT , STOP , PLUS and MINUS button below it. It has on the left a grill/oven at the top and an oven below...
Hello would you happen to have a model number or any serial number on your LEISURE COOKMASTER 101 I will be trying to obtain your specific manual and not provide one that is generalized and these numbers help to locate your exact unit. Thank you I await your reply
Rick
Oct 28, 2011 | Refrigerators
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
Jul 05, 2010 | Kitchen Ranges
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
FAN NOT WORKING,OVEN NOT GETTING HOT ENOUGH
1 How to change a fan oven element and How to change a cooker oven fan Motor
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
1, If the
fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the
element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit i.e. broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven
fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
Mar 04, 2010 | Ovens
Kitchen Ranges Logo
46 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
