Even caked-on iron and rust stains can be removed with a little effort. Apply your chosen cleaners to fiberglass tubs using a soft sponge, a nylon, polyester or polyethylene brush with soft bristles, or a soft cloth. Do not use abrasive cleansers, steel wool, abrasive scrubbers or scrapers on the fiberglass tub or shower surround, as these can scratch the fiberglass--in a gallon bucket: 2 tablespoons of white vinegar, 1/2 cup warm water, 1 2/3 cups of baking soda and 1/2 cup of a liquid degreasing dish detergent. Apply the solution directly to the stain and let it sit for an hour before rinsing and wiping clean.
A vinegar-and-baking soda paste applied to stained areas creates a chemical reaction that can remove the stain through the fizzing action generated by mixing backing soda with vinegar. Apply the vinegar and baking soda paste directly to the stained area and let sit for 15 to 20 minutes before rinsing and removal.
SOURCE: 2 inch crack in shower pan fiberglass floor
I repair such fiberglass shower pan liners in the Philadelphia > NYC corridor. Generally, this fix should cost you between $150 and $500 depending on the size of the shower and how many people in your area do fiberglassing. I would strongly suggest having the entire shower basin re-fiberglassed as opposed to trying to patch the hole. However, a good fiberglasser should be able to fix this in a couple of hours for a few hundred bucks. If you are in our area, visit www.CFINJ.com and contact us. Brian
SOURCE: I need to remove the Maax shower base and can not
Hello, You shouldn't have to resort to that extreme. The drain unit that the retainer sits in is the part securing the base down, have a look at the diagram in this link: http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
The drain assembly should unthread and release the base. But sometimes they tend to work as designed.
The retainer is a compression fit (or should be... do you know the installer? they may have deviated from the described installation). Assuming a proper install, use a flat-head screwdriver and a utility knife to seperate the inside portion of the rubber seal of the retainer, from the plastic ring. The ring should now be able to be pried out, and the drain portion unthreaded.
If this helped, please rate a four-thumbs up. Thank You.
