This information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
* Turn the TV off.* Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
* The TV will turn on with the Service Menu displayed.
* Press the {POWER} button to exit. thank you..
SOURCE: RCA 32" TV
Many RCA's use the following to gain access:
Hold the 'Menu' button while turning the set on.
The code may also be inside the back cover.
SOURCE: I need a service mode
If you are asking how to enter service mode in tv...procedure is like that...
1. TV turned on
2. Press and hold the 'Menu' button at the tv.
3. Press and release the 'Power' button.
4. Press and release the 'Vol up' button.
5. Release the 'Menu' button.
6. The initial security parameter displayed will be 'zero' Change this to '76'.
You are now in the Adjustment mode
For more info, click THIS we blink.
I am a TV technician and have been for 35 years. This procedure did not work. Do you have any other suggestions?
try this cite /www.riddledtv.com/forums/tv-service... thank you
