SOURCE: toilet tank replacement
I believe you will find it cheaper to replace the whole toilet. good luck
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
SOURCE: Need to replace fuel shut-off valve
well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
[email protected]
SOURCE: toilet backs up after use.
The system does not work, as you describe, you MUST use the unit's pump lever as the intake and removal are part of it's function. Use sea water to flush, the system is designed for that.
Man.That is one cap you don't want to loose.
