Sometime the smoke alarm will make a noise when there is no smoke inside the house the house was built 2015 and that when the smoke alarm was replace what i need to check and how to check to stop the smoke alarm from making the noise when there is no smoke in the house?
There may be possible smoke that triggered your alarm or the battery needs to be replaced. Outdated alarms lose sensitivity and may not work properly after several years of service, so it is suggested you regularly replace the smoke detector.
You may be interested in:
How to Care for Your Smoke Alarm
Replace batteries.
Possible smoke or defective smoke sensor, faulty connections.Have the installer to check and replace the sensor
SOURCE: How to reset house alarm after power cut
alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
SOURCE: While on spin, my maytag
Your support bungees or tub shock supports are damaged or dislodged. Does it sound like a grinding or screeching type of noise? More that likely you need to change out the pump assume. Three bolts hold it to the bottom; remove the belt and hoses and change. Very simple operation. Please get back to us if you have any further query or else accept the solution. Thanks for contacting fixya.com
This manual will show how to check the tub supports.
http://appliancejunk.com/ge/washer/31-10008.pdf
