Boating Logo
Rodney Lester Posted on Nov 04, 2017
Can a Volvo Penta D4-260 EVC add a third E-key?
2 Related Answers
Anonymous
  • Posted on May 16, 2013
SOURCE: volvo penta boat manual
What's required to attach the shifter cable at the outdrive?
Randy Ohler
  • 14585 Answers
  • Posted on Oct 16, 2016
SOURCE: How do I find where the hydraulic pumppower trim is on a Volvo penta ad31 boat motor
Mounted to the inside transom. Usually on the starboard side.
Volvo Penta 5.0L Sterndrive. How to Flush after salt water use?
Question edited for clarity.
Question moved from Pool and Spa category.
You can add a flushing valve and use a hose.
https://www.google.com/search?q=sterndrive+volvo+penta+5.0l+flush+valve
Or you can use Muffs to force water into the inlet.
https://www.google.com/search?q=sterndrive+volvo+penta+5.0l+flush+salt+water
1helpful
2006 Volvo Penta 5.0 GL blows the 50 amp breaker and no power to the trim motor! I checked and removed wiring harness did not find any issues. I replaced both trim relays and looked at the key switch.
Question moved to a Volvo Penta Marine category from Cars.
Check the starter motor and solenoid for a dead short. It would take something big to blow the 50 amp fuse.
1helpful
2004 VOLVO PENTA MARINE ENGINE 3.0 LITER - Head Torque please?
Question edited for clarity, 'year make model (what it is)'.
Question moved from Motorcycles to out only Volvo Penta cat.
Volvo Penta 3.0 GL GS cylinder head Bolt Tightening Torques
Volvo Penta 3.0 GL GS Cylinder Head Bolts
Step 1 = 47 Nm, 35 lb.ft
Step 2 = 88 Nm, 65 lb.ft
Step 2 = 122 Nm, 90 lb.ft
Repair manuals. They are seldom free!
https://www.google.com/search?q=2004+VOLVO+PENTA+MARINE+ENGINE+3.0+LITER+repair+manual
I have a 4-cylinder Volvo Penta aq130 a will not pump water has brand new impeller
There are number of pumps, but this one has a half moon keyway in the shaft, does yours have it fitted, otherwise the shaft would turn, but the impeller wouldn't.
https://www.marinepartseurope.com/en/volvo-penta-spare-parts.aspx?Catalog=7736850&Category=26&View=12779
Engine parts and exploded schematics
https://www.marinepartseurope.com/en/e-volvo-penta-344-AQ130C.aspx
1helpful
1helpful
2answers
I need to find a free repair manual online for a volvo penta motor 1979
i have a fivehorese penta outboread engine is it water cooled or air cooled
Top Volvo Boating Experts
ROBERT GARCIA
ROBERT GARCIA
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Volvo Boating Expert? Answer questions, earn points and help others
