Electrical Supplies Logo
L
Lee hoa Posted on Nov 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Onan 5500 generator where is the transfer swich
The generator runs and has power but not get to the coach
Pete Norton
Level 2:
Scholar:
  • Expert 121 Answers
  • Posted on Nov 03, 2017
Pete Norton
Expert
Level 2:
Scholar:
Answers
121
Questions
0
Helped
24370
Points
307
Check your circuit breakers
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Jan 26, 2009
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Anonymous
  • 116 Answers
  • Posted on Apr 17, 2009
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Anonymous
  • 1489 Answers
  • Posted on Apr 30, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Anonymous
  • 77 Answers
  • Posted on Aug 10, 2009
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Anonymous
  • 134 Answers
  • Posted on Nov 11, 2010
SOURCE: Onan generator: Pro 6000e: engine runs, no
Are you getting any kind of voltage output at all?
2answers
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
1helpful
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
1helpful
2answers
Rv generator output, yet no power in coach. Called Parallax about Transfer switch, yet company says just reset the transfer switch, did now says error fault relay switch. Parallax ats501 why now there is a...
Check to see if you have power going into the switch. This can be done with a voltage meter at the terminals were the cable runs into the transfer switch. Do you have power at the generator plug?
Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
